Massey 65-Engine ID help please.
/ Massey 65-Engine ID help please. #1
Mean Jean
Hazelridge, MB
Kubota L1801 and Massey 65
Replacing the valve cover gasket on a Massey 65 and need to confirm the proper valve cover gasket. I see this tractor came with 2 different Diesel engines:
Perkins 4A-203.
It's a 203.5 cubic inch L head engine.
Or
Perkins A4.192
It's a 192 cubic inch engine.
Serial number of tractor is 681068.
Stamper number of motor is RMO 18826-1.
Valve cover has 3 nuts to hold the cover down instead of the usual 6-10 which are along the perimeter. Not sure why I can't post a picture..,
Also
Should I adjust the valve clearance while I'm in there?
Thanks all
Jay D
/ Massey 65-Engine ID help please. #2
G'day I would say if you have three holdown nuts then it is a 192 can't remember a 203 with that setup
Jon
They sump in oil pan is vertical and does not have a "wedge" which leads me to believe it's a 203.
Also, the oil filter is vertical which also indicates it's a 203.
The injectors are vertical which is a trait found in the 192.
Yikes!
2018 RAM 2500 (A65643)
SARLO (A64557)
SARLO (A64557)
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
Crane Carriage System for Steel Baskets (A65579)
Crane Carriage...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
