Massey 60 high oil pressure
   / Massey 60 high oil pressure #1
Longdon
MF 60
HI, I've recently inherited a MF 60 but it runs with very high oil pressure, it comes down a little bit when it's been working and warmed up, but it's still near, or on the red line. I don't have a manual and wondering if anyone on this web site may offer any advice to either the oil problem or manual, many thanks
   / Massey 60 high oil pressure #3
I would check it with a new gauge hooked straight into the oil pressure line where your sending unit is or if the old type with copper tubing running to the gauge, unhook it and tie in a new gauge prior to going to a thinner oil. The old gauge or sending unit may be reading incorrectly.
   / Massey 60 high oil pressure #4
ditto on the new gauge.. and get one that reads in PSI.. not a red / green 'zone'
what oil ya using, and what climate
soundguy
   / Massey 60 high oil pressure #5
My oil pressure always read high, like pegged to the max high. The needle fluttered too. I replaced the oil sending unit and it doesn't flutter as much now and the pressure reads lower (reads around 60 when super hot). But still is somewhat high for the most part. I was told to not worry about it unless it reads way too low and just keep an eye on the oil level.
   / Massey 60 high oil pressure #6
I wouldn't trust any gauge reading without using a master gauge first to verify the actual pressure.
Jim
   / Massey 60 high oil pressure #7
I replaced a leaking sending unit on a Dodge truck once with an auto parts unit and it pegged the needle on the guage. It was working properly prior to replacement, just leaking oil. I took it back and had to go to the Dodge dealer and get an OEM unit. It worked fine. You may have the same problem as the sending unit may not match the electronics in the gauge.
   / Massey 60 high oil pressure #8
yep.. I'd verify with a good mechanical gauge.
I keep a gauge on a grease gun hose whip and use it as a tester when I need a known good reading..
Thanks everyone for their input, think I will start with an oil change which is long overdue then look at getting another pressure guage if oil change does not seem to have an impact. Many thanks again
   / Massey 60 high oil pressure #10
You may have a stuck closed oil pressure relief valve or the oil filter is plugged. Other possible causes are too high oil viscosity for the ambient temperature conditions you are operating in. The last thing I would suspect is the oil pressure gauge unless it is not the correct one for your tractor. The best type of oil pressure gauge is a one with numbers rather than with color bands.
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
