Massey 2850
/ Massey 2850 #1
reddog6601
Fairfield, ME
Massey Ferguson 2850
I need to replace the front wiper blade on my 2850. Dealer tells me that the blade and arm come as a single part.
I can't see how to remove the arm. Has anyone done it and can give me some advice?
Thanks for the help
/ Massey 2850 #2
I don't know who your dealer is, but they can't read a parts book. The I believe the arm is attached with a nut, but the blade just hooks under the end of the arm. Should be a release tab on the wiper towards the motor that releases the blade.
I would think you could take the wiper off and get one at an auto parts store. Agco wants $36. for the blade.
/ Massey 2850
Thanks for the info. Mine is different. The arm does not have a hook end. Somewhere they made a change. For my stile Massey does not sell a replacement blade. The blade and arm come together for (are you ready for this) $81 plus tax and shipping. That would bring it to almost $100. I don't think so. The do have a source for an aftermarket blade only. It is supposed to fit. It is on order
/ Massey 2850 #4
Reddog, you're/they're right! I guess I can't read a parts book. I was looking at the rear wiper.
Why would they make the front different from the rear?
/ Massey 2850 #6
The front wiper blade should be a NAPA 6-016-A. At least it was on 2860 tractor. A very competent MF dealer parts guy figured this out.
/ Massey 2850
Jeez, I guess it been close to two months since I checked this site. I need to pay better attention. Thanks for the info Lou_B I will defiantly pay my NAPA dealer a visit should be the same.
Another question. Has anyone changed the fuel filter on a Massey 2860. I think I have water contamination in my filter We have have had the coldest Decembers on 20 years and I think my fuel gelled and I may have water in the fuel. I always add Power Service in the white jug when I fill my 55 gallon transfer tank. I have also added 911 to the tractors fuel tank and that didn't seem to clear up the bogging down and stalling. It will idle OK but when I put in gear I can't get 50 feet. Any advice will help
/ Massey 2850 #8
Changing the filter is relatively easy. Specific instructions are in the owner's manual, and those instructions actually work. The filter is in an enclosure on the right side of the tractor just forward of the floor platform. Disconnect the water in fuel sensor wire, unscrew the old filter, install the new one, and reconnect the wire. On top of the filter there is a hand pump. Press down on it until it becomes firm. This primes the fuel lines. Using this hand pump is also a good first step in recovering from a fuel gelling problem.
