Massey 2850
/ Massey 2850 #1
reddog6601
Fairfield, ME
Massey Ferguson 2850
I have a Massey 2850 hydro. So far it has been a great tractor. I do need to change the hydraulic filter. Not sure how to go about it. I was hoping someone could give me some info before I get into it. One question is how much fluid will run out when I get the filter out and should I replace all the fluid. Thanks in advance for the info
/ Massey 2850 #2
Drain the hydraulic oil first - then replace the filter. the hyd oil and hyd filter should have the same change interval I think.
/ Massey 2850 #3
I differ in opinion on this. First there is NO reason to drain the hydraulic oil. You will lose a very small amount when you unscrew the filter so have something underneath it to catch that which is no big deal. Certainly various models plumbing are different so unscrew the last couple of turns slowly and see how much fluid you lose on your model. On my 2660 it was 1/2 cup or so. Second, unless there are other issues that point to hydraulic fluid contamination or problems there is little/no reason to do that. It is costly, cumbersome, messy and unnecessary. Sure, if the tractor has 5000 hrs on it and you are doing major overhauls of several kinds ... then go ahead and change the fluid.
I forgot to mention, if you have not changed the hydraulic filter before they are NOT as much like spin on oil filters as they look like. They are about 7 or 8 times as expensive for starters. Much finer micron numbered filtering and very different circumstances involved. I found the NAPA crossover equivalent filters to be just fine BUT they are not cheap either. Be prepared for the $60 to $80 range with the Massey dealer filters being about 10% more costly.
/ Massey 2850 #4
>> I differ in opinion on this. First there is NO reason to drain the hydraulic oil. You will lose a very small amount when you unscrew the filter so have something underneath it to catch that which is no big deal. <<
I agree with this. I don't change my fluid. I only change the filter and top off with whatever amount I lose (not that much). Changing all the fluid is an unnecessary expense in my opinion unless you are using your tractor all day, most days.
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
L6060 Kubota For Sale
207271 (A52708)
207271 (A52708)
Vicsec 30in. Grading Bucket Mini Excavator Attachment (A61572)
Vicsec 30in...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
(8) PLASTIC PALLETS (A63745)
(8) PLASTIC...
