Massey 2760...Using wood chipper but engine kills when I get off the tractor seat
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #1
Huckleberry Ranch
Camino, CA
Massey Ferguson 2760 HST
I know the 2760 has a seat activated kill switch if you try and get off the tractor with the pto engaged and running.
All fine and good until I want to use my new pto driven wood chipper.
Am I missing something or do I need to resort to manually overriding the seat switch?
I put the hst trans in neutral and the brakes locked on.
Thanks in advance!
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #2
Manually override. Sometimes a cinderblock in the seat is sufficient. W. JONES
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #3
Read your owner's manual. Kubota has a work around for this issue, Massey may, too. With Kubota there is a delay on the engine kill. You get off the seat and within one second (or was it two?) you flip the seat up and the engine continues to run.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #4
What's the Massy Ferguson operators manual say about seat kill switch and deactivation? A lot of 3pt implements require the operator to be at back of the tractor, including cement mixer, Stump Grinders, Wood Chippers and log splitters.
Perhaps you could do a temporary wiring bypass on the seat kill switch.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #5
Though it violates every safety sticker on tractor and a dozen pages in owners manual. IF no solution is mentioned in tractor manual, I suggest seat switch bypass switch WITH BIG WARNING LIGHT seat switch is deactivated...
Dale
Thanks for the replies. The manual section “ seat switch “ just says if the operator leaves the seat with pto on, the engine will stop.
I will try lifting the seat all the way up, thanks for the suggestion. If not, cinder block �� it is.
Yesterday I used neighbor. Cinder block seen as upgrade.
Update....raising seat doesn’t work, gonna tape her down.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #7
My switch lever is a piece of plastic, which is wired down to prevent it from activating. It was pretty hard to run the backhoe from the front seat.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #8
On the Massey I just traded in for the Kubota, there was a yellow button on the left rear fender, to operate the PTO without the driver being on the seat. I can't remember exactly how it worked but I think you had to leave the PTO in neutral in the cab and when you pushed the yellow button the pto would start up after a few seconds. Much better than the Kubota with the air ride seat. In the Kubota I had to bypass the safety switch.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #9
That would be my preferred choice, is a hardwired bypass switch, that keeps the factory installed seat kill switch fully active, until you throw your switch to bypass when using a PTO chipper. Then switch back to renegage the seat kill switch.
My Kioti CK4010 came with no installed seat kill switch, so I thought all tractors were the same way. Mine is a live PTO clutch, and not an independent PTO.
   / Massey 2760...Using wood chipper but engine kills when I get off the tractor seat #10
20# sack of dog food in your lap. Leave dog food in the seat as you exit tractor. I simply don't believe there is not a legit way to do this.........
My M6040 will buzz for ten seconds. Then silence and all continues to operate. It's a warning - not a kill.
Scag STT52V-27CH 52in Zero Turn Commercial Mower (A55851)
Scag STT52V-27CH...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A57880)
2007 TEREX ADVANCE...
Roto Grind 760 (A53317)
Roto Grind 760...
