Massey 271xe - Dash / Gauge Cluster Rubber Mounting gadgets
   / Massey 271xe - Dash / Gauge Cluster Rubber Mounting gadgets #1
herrmc
Agra, Ok
MF-271xe, MF-230, MF431, IH-826
Greetings,
I have a Massey 271xe -- 2002 Year (I believe).
The gauge cluster (mounts in dash panel) is mounted with (4) rubber gadgets (anti-vibration) ...
-- The mounting "gadget" mostly a "rubber" part ....
> Hole through the center allows a 3/16" bolt/screw to fasten it to the main dash panel.
> The other end of the "Gadget" is an Aluminum Plate (1.76" x 1.76")...
> plate has (4) small holes (1 at each corner) -- about 0.16" diameter ... these holes "pop-rivet" to the Gauge-Cluster-Frame
> That aluminum plat has a "large" hole in the center (about 1.25" inch)... the rubber is fused to the aluminum plate in this hole.
-- Part Number --- I need the part Number..... and any advice on where to obtain.
Massey Ferguson dealers used to be common around where we live... and they can't hardly be found anymore ... I have contacted the closest dealer... but I haven't hear back.
*** The rubber is "rotton" on my mounts... and they are all loose... need replaced.
   / Massey 271xe - Dash / Gauge Cluster Rubber Mounting gadgets #2
herrmc:
Yours appear to be in much better shape than mine on a 251XE. I did not drill them out, but replaced the inner parts with 2 different diameter automotive hose sizes between some larger washers so the panel could move back and forth through the mounts. A year later it is still working..
OR
You can access parts books 24/7 at AGCO Parts Books. Put the parts you are needing in the shopping cart to email to us or call us and we can give you the prices and availability of the parts you are needing. We ship out by UPS daily all over the US and Canada.
Go in as guest -
Company is:
Schmidt & Sons, Inc
Mt. Hope, KS 67108
316-445-2103
800-281-2164
Schmidt & Sons, Inc. - Your dealer in South Central Kansas for New and used Challenger Massey Ferguson tractors, Gleaner Combines, and Hesston Hay equipment
inquire@schmidtinc.com
Starkiller
--- Thank you for the response!!!
--- the picture is deceptive regarding the condition ... they are actually all apart in little pieces... I assembled that one back on my desk (from the pieces) so I could have picture of what it should look like :)
--- That is a good Idea about the hoses .... I was thinking of using small springs. I have a machine shop, so making some stuff isn't too big of a deal...
Curtis
herrmc:
OR
Go in as guest -
Company is:
Schmidt & Sons, Inc
Mt. Hope, KS 67108
316-445-2103
800-281-2164
Starkiller
-- Thank You for the link to the parts book!!! ... this is very helpful.
--- I found my part on page 348 of the 271 XE book
Item #7
Part Number = 3609301M1
Description = "Damper"
Qty Required = 4
-- this is going to be very helpful!
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
