Massey 255 won't start after winter - help!
   / Massey 255 won't start after winter - help! #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
My trusty Massey 255 with the larger Perkins diesel engine won't start after the long and cold winter.
This was the first winter it was parked outside (could not help it) and I typically start it every couple months in the winter to let it warm up and the battery charge. This year I didn't until Jan/Feb and after I got the block heater on her she started find but after 5 minutes, died like she ran out of fuel. Didn't start again in the winter.
I realized in the spring that it was probably out of fuel. So I charged up the battery with the trickle charger. Added new diesel and followed the fuel system bleeding instructions in the owners manual.
No go. Still won't start. Cranks but does not fire up. Out of battery again so I have to trickle charge it.
I put anti-gel stuff in my diesel tank that the tractors get fueled up for so I didn't think gelling would be a problem but who knows. I have not taken the fuel filter out yet. Figure that is my next step to see if I have any gelled stuff there.
I'd appreciate your thoughts on what I should check next to diagnose it before I hand in my man card and send it to the dealer.
   / Massey 255 won't start after winter - help! #2
There shouldn't be any gell anywhere now as summer diesel only gells in cold weather. If you have blead everything as per the manual them there should be fuel in the injection pump. Try loosening each injector line at the injector and cranking the engine till fuel appears at the injector. Tighten the lines up and the engine should start.
I did loosen the injector lines and cranked a couple times. Had fuel come out of one I think. Maybe I didn't crank enough to have fuel come out of all before I tightened up? I figured a couple cranks ought to be enough but I guess I should have waited to see fuel out of all of them.
Of course the subsequent cranking after tightening has killed the battery so I must charge it up again :-(
When the battery is flat is it ok to turn the charger up to 50A setting and start cranking? I've only ever trickle charged before.
   / Massey 255 won't start after winter - help! #4
I don't think it will hurt anything but I don't think that 50 amps is going to be enough to turn over an engine with a low battery. You would have to charge the battery for a while to add enough to turn the engine over. I would for sure turn the charger up to 50 amps while cranking as that will only help out your battery.
Worked perfectly! I just hadn't bled it enough. Went through the procedure again and had air bubbles at the injection pump. Pumped the priming lever till I got clear fuel, loosened the injectors and cranked quite a bit until I got fuel coming out of all 4. Tightened them and cranked. Took some cranking but she fired right up... runs like the top she always was.
   / Massey 255 won't start after winter - help! #6
hit the intake with a little starting fluid or soak a rag in gasoline and hold over the intake she should come alive !!!!!!!!!
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2005 GMC 8500 (A50123)
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
