massey 231s diesel smoke
   / massey 231s diesel smoke #1
malcolmz64ss
senatobia ms
3000 ford
I have a 2000 model Massey 231S that smokes all time. How can I advance the pump timing to stop this? I can't find any service manuals to copy or buy. Thanks
   / massey 231s diesel smoke #2
I doubt timing is the issue. Timing does not change unless you take off the pump or have a mechanical failure. More likely you have bad injectors, bad valve adjustment or low compression. It could also be a bad pump but would not be my first guess.
The reason I think it is pump timing is because this is a commom problem with Ford diesels because of wear to timing gears. Rotating the pump a few degrees cures the problem. I don't know the correct way to check pump timing on this model Massey.
   / massey 231s diesel smoke #4
Hi -
I would not suspect pump timing initially, it is possible but highly unlikely. I would do a compression check on the engine and make sure it's at least 350 PSI, and if so I would have the injectors cleaned and adjusted by a diesel injector company, or replace them.
Injector timing and slop in timing gears is not a simple thing - I would suggest getting a factory manual that discusses the specs on the gears, and timing the crank/cam/injector pump.
Good luck!
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2012 FORD F-550 SUPER DUTY FLATBED (A52472)
2012 FORD F-550...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
