massey 231s diesel smoke
   / massey 231s diesel smoke #1
malcolmz64ss
senatobia ms
3000 ford
I have a 2000 model Massey 231S that smokes all time. How can I advance the pump timing to stop this? I can't find any service manuals to copy or buy. Thanks
   / massey 231s diesel smoke #2
I doubt timing is the issue. Timing does not change unless you take off the pump or have a mechanical failure. More likely you have bad injectors, bad valve adjustment or low compression. It could also be a bad pump but would not be my first guess.
The reason I think it is pump timing is because this is a commom problem with Ford diesels because of wear to timing gears. Rotating the pump a few degrees cures the problem. I don't know the correct way to check pump timing on this model Massey.
   / massey 231s diesel smoke #4
Hi -
I would not suspect pump timing initially, it is possible but highly unlikely. I would do a compression check on the engine and make sure it's at least 350 PSI, and if so I would have the injectors cleaned and adjusted by a diesel injector company, or replace them.
Injector timing and slop in timing gears is not a simple thing - I would suggest getting a factory manual that discusses the specs on the gears, and timing the crank/cam/injector pump.
Good luck!
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
3pt 7' Tiller (A50121)
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
(2) Military Front & Rear Differential (A50121)
(2) Military Front...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
