Massey 231 front loader help
   / Massey 231 front loader help #1
Zeke1eod
Massey Ferguson 231, Long 360, Kubota B3200
I have a June 93 Massey 231 with a Massey 295 front loader and shaft driven external pump. It's always seemed weak/slow, now it will not lift at all. I checked fluid it was 1 gal low, and white ish milky possible water intrusion, which is odd always kept in dry, not crossing creeks etc. Looking at local dealers for filter screen and gasket. The draft and position levers are in up position and you can hear the pump engage, pto works and it will drive, if I tie loader joystick back and walk to front, pump is turning, I have service manual but hydraulic diagnostic info is weak, what should I look for, any valves on transmission or elsewhere? I have numerous pressure gauges up to 5k psi, where would I plumb gauge into check pressure and what psi should I use? Thanks in advance
2013 Ford F150 Pickup Truck (A53422)
2013 Ford F150...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
Hose Reel (A53424)
Hose Reel (A53424)
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
