Massey 1835M oil leak through breather tube
   / Massey 1835M oil leak through breather tube #1
Lintlaw
1835m
Hello -- I have a 2020 Massey 1835 with about 120 hrs has been excellent until yesterday. We have traced the engine oil leak to a breather tube that is located near the steering column at the back of the cab.....ok at idle but at 2200plus rpm .....is a steady stream out of that little black breather vent tube
   / Massey 1835M oil leak through breather tube #2
Sounds, like it's under warranty so maybe a trip to the dealer is in order. You per chance didn't overfill the crankcase with oil?
sorry by the column front of cab - the rear of cab is good-- and at idle oil is fine- rev it up....then it spits it out as a stream...talking with dealer but big snowstorm and christmas...and shipping delays...was wanting to try and use a little bit----if get it figured.
   / Massey 1835M oil leak through breather tube #5
How is the oil level? Did you check it? I wonder if the shaft seal on one of the hydraulic pumps failed and its filling the crankcase with hydraulic fluid.
this is the engine oil and because of the cold weather here - i had caught the issue and added oil a few times , to move it into our shop to investigate---no other lines seem loose or have leakage just the vent line when at above 2000 rpm and had been rechecking each time--and the oil was visibly dripping out
Well - warranty - found out an element froze up and then a seal went along oil into Bell housing-- they put a circulating heater and routed the hoses to keep the element warm before and during use
So was fixed under warranty - had it back was using oil- 3 Liters in an hour-- replaced turbo but motor on order - 2 months away if lucky
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2016 Bad Boy 54in. ZT Elite Zero-Turn Lawn Mower (A53117)
2016 Bad Boy 54in...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
