massey 1660 pto problems
   / massey 1660 pto problems #1
Mud Mechanik
Hurley, Mississippi
Massey Ferguson 1660
My 1660 now has about 129 hours on it, have not used the pto this winter. I just hooked up the brush hog and to my surprise, the pto will not work, the instrument panel thinks it is spinning and the tractor will shut down if i get off of the seatbut the shaft is not spinning. Has anyone had a similar issue with their massey? I have checked fuses, thinking maybe a solenoid has blown one...but they are all good.
   / massey 1660 pto problems #2
Is the lever on the left side of the seat engaged?
Sent from my iPad using TractorByNet
Now i feel like an idiot....i am not used to having a lever and a switch to engage the pto....thanks for the reply and you were spot on...the lever was disengaged. I was ready to send the tractor back to the dealer...sometimes we cannot see the forest for the trees.
   / massey 1660 pto problems #4
You won't be the first or the last. I put the lever on once and just turn the pto on with the dash button.
   / massey 1660 pto problems #5
I use the lever to disengage the PTO when I use the brush hog to prevent wear on the PTO brake. The high inertia of the brush hog will burn up the brake prematurely. And yes I have done the same thing as the OP, and forgot to engage the lever :banghead: and been wondering why the PTO didn't work until I remembered the lever.:duh:
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A53426)
2004 HYUNDAI...
2018 Ford F150 4x4 Pickup Truck (A51692)
2018 Ford F150 4x4...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
21008 (A51694)
21008 (A51694)
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
