Backhoe massey 165
   / massey 165 #1
steve42rich
hubbard tx
165 massey ferguson
If a tractor has a bad pilot bearing how can you tell will it make noise thanks steve ot's a disel engine
   / massey 165 #2
G'day steve.
If there is a noise in the area of the clutch it is normally the Release bearing If the clutch adjustment is neglected at any time the release bearing will run constantly and with the heat from the clutch will dump all the grease in the bearing and it will start to SQUEEK and rattle,The pilot bearing will also make a noise if it is dry and in advanced stage of wear will make it hard to select the pto and you will find that the pto does not stop turning.
Thats all.
Regards.
Hutch.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51242)
2004 DYNAPAC...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
