Massey 165 will not start
   / Massey 165 will not start #11
I agree. It does sound like a dud injector pump.
I grew up on a hill country farm, (easy rolling to too-steep-for-a-tractor) and we had multipower gearboxes on both the 135 and 178, and both 2 wheel drive.
What tractor would you consider more suitable for you?
I have been looking at the LS XR37, they are quite a bit cheaper than the Kubota's. Just not sure about the longevity, can't find anyone who has had one very long.
Most of the tractor work I need to do is dirt work, auger, and occasional mowing
   / Massey 165 will not start #13
G'day i see earlier that you replaced the o rings on the throttle shafts my bet is that you haven't picked up the stop linkage properly in the top of the inj pump which is very easy to do might not hurt to lift the cover and check. I push the shaft through a bit so you can see the control cam and see that the pin goes into the hook properly.
Jon
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
