Massey 1533
   / Massey 1533 #1
JD5325
Arkansas
JD 5085E / Kubota M5140 / MF 383 / Duetz 6006
Hello, Was on my 1533 yesterday when I heard a Pop and saw Smoke on right side of motor. After Investagation I determined it was the Solenoid on the back of the injector pump ( melted the rubber cover ) has anyone ever seen one of these short out before ??? Thanks for the help
   / Massey 1533 #2
Sorry I can't help you but I posted about my JD4100 MAKING A POP AND A POOF. Not sure how comparable our tractor are but how did you determine the injector solenoid and where is it located?
   / Massey 1533
Well on my Massey 1533 it is on the very back of the injector pump, it is held on with 2 screws. I believe this solenoid is the equivalant of a kill switch. I know after this happened I turned it off and then it wouldnt start back, so I took it off and then it would start but wouldnt turn off. So I had to put it in high gear and let out on the clutch to kill it !!
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A50397)
2016 Ford F550 4x4...
2012 IC Corporation PB105 School Bus (A48081)
2012 IC...
UNUSED RAYTREE QUICK ATTACH 72" DRUM MULCHER (A50460)
UNUSED RAYTREE...
5ft Set of Disc Harrows (A48837)
5ft Set of Disc...
377782 (A48837)
377782 (A48837)
