Massey 1529 fuel filter replacement
   / Massey 1529 fuel filter replacement #1
massey29
Sandstone MN
Massey 1529
After7 years and only 300 hours, it is beyond time to replace my fuel filter. After installing do I need to bleed the system with the two indicated air bleeding bolts?
What is the recommended fuel filter change period?
Thanks for any replies
Terry
   / Massey 1529 fuel filter replacement #2
YES.. get fuel coming out of the bolts & snug back up.. NOT super tight.. just enough to stop any leaks.
Once u start your tractor, hold the throttle at MID throttle for a few minutes.. you'll HEAR IT struggling & then clear up..
IF it dies on u, u can use the bleeder screw on the injection pump, by the name plate..
Its a double screw w/ a bleeder.. Loosen the 5/16 portion of the screw & spin the engine OR if it has an electric supply pump, just turn the key on & wait for fuel to come out.. NOW its bled.. Go ahead & restart it..
To be on the safe side.. change 2x a year.. The damage is already done tho, after 7 years.. so don't be surprised when your pump goes out or it starts to smoke..{prob. bad injectors}
Happy Tractoring..
Thanks for the reply
Put in the new fuel filter. It took five minutes. Runs way better ,smoother, less black smoke on startup. Changing it every year from now on.
   / Massey 1529 fuel filter replacement #5
I am now at 7 years and 300 hours. 1st fuel filter replacement. Still having trouble trying to bleed the system. It strarts and runs fine for a couple of hours then starts losing power. MF 1529
   / Massey 1529 fuel filter replacement #6
I think u answered your problem in the 1st 2 sentences..??
Have u LOOKED INSIDE the tank.??
I think they have a filter SCREEN built onto the outlet/shut off tap.??
I would suggest pulling the hose off the bottom of the tank, run a separate hose into a 5-10 gallon bucket..
Look for debris and once it got low enough, unscrew the outlet/shut off tap..
And for goodness sake, CHANGE THAT FILTER 2x a year.!!!
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
