Massey 135 Tranny/hydraulic fill cap
   / Massey 135 Tranny/hydraulic fill cap #1
johnking
greenville sc
1965 Massey 135
The fill cap for my tranny is rounded. Am I looking at the right thing or should I just put vise grips to it and open it up? 156.jpg
   / Massey 135 Tranny/hydraulic fill cap #2
Yes, it the one left of the shifters. Clean the dirt from around it before opening so nothing falls in. Used to be a hex for a wrench, obviously someone decided pliers or vicegrips are better. Ha Ha.
   / Massey 135 Tranny/hydraulic fill cap #3
The plug on the left is it. Can you file some flats onto it so you can get a wrench on her. Do you have a reason to remove the plug? If the 135's are like the 255's there is a dipstick back behind the right foot board about 3/4 way up the casting.
I need to change the tranny oil, the current has water in it(white colored)>
   / Massey 135 Tranny/hydraulic fill cap #5
johnking said:
The fill cap for my tranny is rounded. Am I looking at the right thing or should I just put vise grips to it and open it up?<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=277779"/>
john, be sure to replace those shift boots which probably allowed the water inside. i've got to replace the PTO seal in mine and going to replace the fluids while I'm at it. i also have new boots for the shifters.
   / Massey 135 Tranny/hydraulic fill cap #6
Yep, that's the transmission fill plug, but to drain the hydraulic fluid you'll need to remove the two drain plugs from the bottom of the transmission and differential housings, both being located on the same side as the transmission fill plug. Since yours is damaged, you might consider replacing the transmission fill plug (768300M1) with a new one, which should only cost about $10.
The following is a picture of my Massey 135 tractor's transmission fill plug, to give you a better idea of what yours looked like before the corners were rounded off.
You guys are great, thanks.A new plug and boots. I will be storing the tractor indoors or undercover also.
   / Massey 135 Tranny/hydraulic fill cap #8
John, you probably have a good chance of finding a replacement cap from a salvage yard online. Probably doesn't cost much either.
   / Massey 135 Tranny/hydraulic fill cap #9
The shipping will cost more than a new plug from MF. Last time I replaced boots, they were around $10 each. Go see your local dealer.
   / Massey 135 Tranny/hydraulic fill cap #10
The fill cap for my tranny is rounded. Am I looking at the right thing or should I just put vise grips to it and open it up?View attachment 277779
Try the vise grips. If that doesn't work, I'd tack weld a hex nut to the cap with my stick welder.
Good luck.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 1GNFC16047J152289 (A51572)
2007 Chevrolet...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
