massey 135 solenoid engages but starter motor won't turn over
   / massey 135 solenoid engages but starter motor won't turn over #1
joetrotter
Tobaccoville,nc
massey ferguson 135
Hey guys,
My '65 135 diesel won't start. I'm no mechanic but I did try a few things. I can hear the solenoid kick in, but no starter motor. I turned on the key switch and then held a screw driver from the large 12V lug on the solenoid to the starter motor and it fired right up. I figure its the contacts in the solenoid. There is a fuel leak (very very very slow drip ) from above the starter. I'll need to fix that. Figure its the gasket in what ever that thing is above it. It has a manual lever on it. Anyway, was wondering if 1) I'm on the right track or missing something 2) can I take the top off the solenoid and clean or replace those contacts 3) do I have to buy both a solenoid and starter motor or solenoid alone 4) what is that above the solenoid that is leaking and its purpose?
Thanks for any help for this total newbie
PS I actually don't mind when something not to major goes wrong cause I've never had the opportunity to work on anything and I love learning.
   / massey 135 solenoid engages but starter motor won't turn over #2
That is the lift pump (some call it a fuel pump). The manual lever is used to prime the fuel system, it lets you use the lift pump without the engine running (you can work the pump with the lever, but not with the engine running).
thanks Kenneth S. Now I can at least not soound stupid when buying a gasket.
   / massey 135 solenoid engages but starter motor won't turn over #4
Hey guys,
The contacts in the solenoid are probably arced pretty badly and won't pass sufficient current to cause the starter to turn over. You bypassed those contacts with the screwdriver and that's why it started. Kinda' hard on screw drivers though! You maybe able to open the solenoid and rotate the starter contacts or clean them up, or you can spring for a new solenoid.
thanks Jerry/mt,
I found a solenoid aftermarket for $20 shipped. I may try to clean the contacts, but at worst I can replace the entire solenoid pretty cheap.
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A55787)
2009 Yale...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2021 TAKEUCHI TB240 EXCAVATOR (A52705)
2021 TAKEUCHI...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2017 Ford F-550 Knapheide Enclosed Service Truck (A55788)
2017 Ford F-550...
