Massey 135 rubber elbow at air cleaner continetal engine.
   / Massey 135 rubber elbow at air cleaner continetal engine. #1
popknot7223
Tulsa, OK
Massey 135
I have a cracked air inlet elbow connecting the air filter to the carb on a 1972 Massey 135 with a Continental Z145 gas engine. The tube is 2" ID at the air box connection, it reduces down to 1.5" ID while making a 45 degree bend and connecting to a metal tube headed for the carb. Length is about 5". Does anyone have a part number or know where to find one? I haven't be able to find anything on the internet. I find lots of stuff on the Perkins, but not this elbow on the Continental.
   / Massey 135 rubber elbow at air cleaner continetal engine. #2
Use the AGCO partsbook to find part & number for you 135. Enter as a guest user, and click on the "view books". On the next page that appears, enter your model number, and manufacturer.
AGCO Parts Books
Here is the part number I came up from that site doing a quick search. 521108M1 I used Google to do a part number search , and the description in one said length was 10", so not sure it is the right one. Better double check on my findings. Also ran the number through NAPA, but just showed a section of 2" radiator hose, not a preformed, reduced hose like the others.
Hope this helps..!!
Thanks DJ. Found it in the AGCO Parts Books you referenced. The part you looked up was for the Perkins, but I found the listing for the Continental. Turns out the Continental has an early style air cleaner (vertical) and a later style (hoizontal). Mine is the later style with hose number 513316M1 accordning to the catalog. However the air tube doesn't seem to exist on the internet. A google of just the part number comes up with a belt. Guess I will hunt for a radiator hose to cut to match.
   / Massey 135 rubber elbow at air cleaner continetal engine. #5
Might be able to find something in summit racing website, may take some scrolling and clicking but should be able to find. Good luck always a pain when needed parts come up not available
   / Massey 135 rubber elbow at air cleaner continetal engine. #6
Sorry, just saw gasser and went with that. You could look for your nearest AGCO dealer, and see if they carry the part. Most dealerships allow you to set up a credit card account, and UPS/FedEx parts. I do that a lot, when I'm busy, and don't have the extra time to be gone for 2 hours running parts.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Swict Q.A 66" Bucket (A50121)
Swict Q.A 66"...
