Massey 135 perkins 3cyl gas cracked head options
   / Massey 135 perkins 3cyl gas cracked head options #1
bryanp66
Granite City, IL
Massey Ferguson 135
Hi everyone,
I noticed white sludge and antifreeze on the head when I went to do a valve cover change on my 135 with gas perkins 3 cylinder. I don't have any white smoke, oil in coolant or coolant in oil. The engine runs great. I knew I had a head gasket issue so I pulled the head and the gasket was blown between 1 and 2 cylinders. When I got a closer look I found a hairline crack running from the exhaust valve outward in #2 and also a hairline from the spark plug hole to the intake valve. I am not sure if this is where the coolant got in originally, but I suspect a previous owner had overheated it at some point. Anyway, I am looking at repair options. I could have the cracks pinned, but it would be very expensive. Probably more than a reconditioned head. However, I have searched high and low on the web and cannot locate a head for the GAS 3 cylinder anywhere. The diesel heads are all over the place. Are the gas heads really that rare?? What are your thoughts on this??
Bryan
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
