Massey 135 no start
   / Massey 135 no start #1
forty9ford
kelowna BC
Massey 135
i changed O ring seals on banjo fittings as they were weeping. had to loosen the injector pump to get at rear port. re tighted and bled system, but cannot get even a bit of a weep at injection ports. lots of fuel at supply and return lines, and both low and high bleed ports on pump body. Turns over good but not fire at all.\
Any help would be appreciated.
   / Massey 135 no start #2
Could be a timing problem if you moved the injector pump.
   / Massey 135 no start #3
did you loosen the injector connections @ each cyl then turn over engine to prime the lines? is this a 3 cyl perkins? sounds like you have fuel to the pump, but maybe air pockets from there to cyl...good luck
2014 Gillig Transport Bus (A50323)
2014 Gillig...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
