Massey 135 no start
   / Massey 135 no start #1
forty9ford
kelowna BC
Massey 135
i changed O ring seals on banjo fittings as they were weeping. had to loosen the injector pump to get at rear port. re tighted and bled system, but cannot get even a bit of a weep at injection ports. lots of fuel at supply and return lines, and both low and high bleed ports on pump body. Turns over good but not fire at all.\
Any help would be appreciated.
   / Massey 135 no start #2
Could be a timing problem if you moved the injector pump.
   / Massey 135 no start #3
did you loosen the injector connections @ each cyl then turn over engine to prime the lines? is this a 3 cyl perkins? sounds like you have fuel to the pump, but maybe air pockets from there to cyl...good luck
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
