Massey 135 Lift Operation
   / Massey 135 Lift Operation #1
doxendine
Massey 135
I have a Massey 135. Maybe 1963 model or so with Perkins 3 cyl engine and the 4 speed transmission with high and low range. The problem I'm having is after running through a small ditch while mowing the bush hog kinda dragged the ground when the front of the tractor was coming up throught the swell. At that time the bush hog came up on it's own and the pump was making a noise in the tractor. After a few seconds the pump quits knocking but the lift will not go down. I can fiddle with the lift lever and the lift will slowly go back down. I then pull the lever up a bit and the lift then goes all the way up and the pump knocks again. Happens everytime? I've tried the draft control different positions but no difference. Anyone?
Anyone?
   / Massey 135 Lift Operation #3
Just guessing, but it sounds as though something's jumped out of position.
Maybe better-experienced minds can help if Admin can move this thread to Classic/Vintage.
Or else everyone's as stumped as me. Best of luck!
   / Massey 135 Lift Operation #4
The toplink response spring for the draft control system has been overextended and bent some of your 3ph linkage. It takes a professional trained individual, very good eye, and a manual to fix this problem.
You also need a 3 pound weight, string, a bolt on stopper for the walking beam(i don't know the part number), and a pivot to hang your weight from the walking beam. I can take a picture of the directions and post them of you want to tackle this, but you must be prepared with the above equipment.
Bobcat Skidloader Trencher (A50774)
Bobcat Skidloader...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
