My 135 made a horrible noise coming from the starter area. At first I thought I had a bad bearing and my engine was falling apart. It will start and then it sounds like a grinding between two gears. I shut it down but before I did, I got off to see if I could find the problem area. Is this common and is there an easy fix? How difficult is it to get the starter off, just the 2 bolts holding it to the housing? It looks like there are 2 smaller bolts on the end of the starter housing, wondering if that would be the way to check it out. I have no idea. Thanks for any suggestions you guys my have.
Sean
Sean
