Massey 1250 Tires
/ Massey 1250 Tires #1
tj200
Bronze Member
NY
Massey 1250, Mahindra 4550
Hey Guys,
I did some searching around and have come up with a formula to calculate the tires that I could run 0-5% front tire lead.
(front rolling x 1.6077771) / rear rolling
subtract 1 and mult 100 to get the ratio.
I have a question. I have bald turf tires right now.
Front= 212 80 D15
Rear= 355 80 D20
I was wondering if I could get away with keeping my turf tire and run ag rear and R4 in front
run firestone
front= duraforce dt tl- 215 70 D15- 7 inch rim width- 79 rolling
rear= radial 4000 tl r-1w- 360 70 R20- 11 inch rim width- 126 rolling
After my calculations that gives me a .8% ratio (which is perfect)
But I was wondering if these tires would fit. It is hard to get an exact rim measurement. ( I have googled until my eyes hurt) Does anyone know how wide the turf rims are? I am hoping my time spent on the firestone site along with the calculator will pay me off. (keeping my current rim combo)
/ Massey 1250 Tires #2
My op manual (1240/1250/1260) says you are not supposed to mix R4s and R1s (assuming you have 4WD). It lists your R1/AGs choices as 12.4x24 (rear) with 7x16 fronts or 13.6x24 (rear) with 8x16 (front). If you want to go with R4s your choices are 15-19.5 (rear) with 25x8.5-14 (front) or 14.9-24 (rear) with 10x16.5(front)
The manual implies but doesn't state explicitly that the 13.6x24 (rear) with 8x16 (front) combo fits on the same rims as your turf tires.
Hope this helps!
Jeff
/ Massey 1250 Tires
Unfortunately the front rims are 15 and the backs are 20. Arent your tires in the front R4? And your rear are R1?? I was looking for the same setup as what you have and some others that I seen.
/ Massey 1250 Tires
I cannot get a good picture since its raining outside, but my rims look exactly as this guys
http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/186071-mf-1250-a.html
I wouldnt mind even having all r4? tires in this picture. I pm'ed the guy but have got no response. If someone could help me out and tell me what size these tires are that would be awesome!
/ Massey 1250 Tires
Really? For some reason I always thought r4 are the squared off tires like the ones I threw up in the pic??? and like the ones you have in front.
/ Massey 1250 Tires
Awesome,
Hey Jeff thanks for your support in this. It is confusing. I will do my best in getting the pictures over to you when it stops raining :p
2015 CATERPILLAR 259D SKID STEER (A60429)
2015 CATERPILLAR...
2017 GENIE S-45 TELESCOPIC BOOM LIFT (A60429)
2017 GENIE S-45...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2021 BOBCAT S66 R-SERIES SKID STEER (A60429)
2021 BOBCAT S66...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
