Massey 1250 - Hydro Filter
   / Massey 1250 - Hydro Filter #1
Mike_VT
Vermont
Kubota L4740 HSTC
Does any on know if there is an after market Hydro filter? I Purchased a Wix 57110 definitely not the correct fit!!
Also is there a transmission filter on the 1250 with powershuttle?
   / Massey 1250 - Hydro Filter #2
Sorry. I did have a part number for a fleetguard filter, but I can't find it.
   / Massey 1250 - Hydro Filter #3
Our local NAPA dealer was able to quickly cross-reference all of the filters on my 1240. The last filter change was made easy and cost a lot less using NAPA filters, which are made by WIX.
Jerry, no problem. Based on your fleetguard lead, I was able to do some research. For a Massey 1250 with powershuttle you have two choices. 1) ACGO part # 3607790m1 or FleetGuard HF35223.
The H&L tooth and adapter worked out fine the only difference was the space on the adapter to slide over the bucket was 3/8 and should be smaller. When I welded the adapter on I filled the difference.
   / Massey 1250 - Hydro Filter #5
<font color="blue"> When I welded the adapter on I filled the difference. </font>
That is what I did when I put on MF 50 Industrial shanks on my 16" bucket. I can't even tell they have worn since I put them on. They are a lot better product than the ones that came on it.
   / Massey 1250 - Hydro Filter #6
Almost forgot. I did find a Napa number. It is a Napa #7110.
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
3 pt Aer-Way (A50514)
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A49461)
2008 Ford F-450...
