massey 1250 glow plugs???
   / massey 1250 glow plugs??? #1
v84me
I have a massey furguson 1250 diesel 4wd with loader. when i start eh tractor i get a glow light but have to crank the engine for about 4 or 5 seconds before it fires and then a ton of black smoke blows out for about 15 seconds. is this normal as it has done it ever since i bought it used. glow plugs have about 1.34 resistence on each plug.
any advice please
Randy:(
   / massey 1250 glow plugs??? #2
Sounds about right. Have you tried the throttle in different positions to help in starting?
   / massey 1250 glow plugs??? #3
I have a 1240 and mine does the same type of thing... I found that running the throttle higher helps with the start.. It will put out a lot of black smoke and miss a little on the start but runs smooth after about 10 seconds.
According to the dealer this is pretty normal for these tractors..
   / massey 1250 glow plugs??? #4
I have a '99 1250 I bought new, it has always done the same thing.
   / massey 1250 glow plugs??? #5
I've only got a 1235, but have the same thing. The manual suggests starting the tractor with the throttle half open. Certainly with mine that does mean it fires practically first turn and the black cloud is minimsed!
thanks for the tip
I will try that and see if it helps.:thumbsup:
   / massey 1250 glow plugs??? #7
my fathers mf 1250 does same thing- it blow black smoke upon starting up.
   / massey 1250 glow plugs??? #8
I was thinking the same thing about a possible problem with the glow plugs on my MF1040. I have to preheat the plugs for about 1 min even when its 70-85 degrees outside. Still rolls smoke out for the first couple seconds. After about 10 seconds it clears up, but if the tractor sits more than about 30 min I have to preheat.
Mercury Salt Water Boat Motor (A50121)
Mercury Salt Water...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
