Loader Massey 1205 Compact Utility Tractor Loader Valve leak?
   / Massey 1205 Compact Utility Tractor Loader Valve leak? #1
hb2u
MF 1205
Howdy folks. I'm hoping someone here can give me some guidance on fixing a leaking control valve.
I have a Massey 1205 compact utility tractor with model 1242 loader. it's got a Nimco control valve with a joystick for the loader.
The rear of the valve has developed a leak. The oil appears to be coming from the Caps at the rear of the unit that cover the spools.
What I'm not clear on is whether or not this is an issue with the gasket for the cap, or an o-ring on the spool itself that blew out and allowed oil to get as far as the cap.
There's a couple of little allen screws that hold the caps in place and I tightened them a little, but it did not slow the leak .
I'm mechanically inclined, but this is my first tractor with hydraulics, so I'm not familiar with how these things go together and come apart. Any tips/tricks/or noted special tools that might be needed would be greatly appreciated.
Am I wrong in thinking that I can just replace a couple of o-rings to fix this?
Thanks for your input.
HB
   / Massey 1205 Compact Utility Tractor Loader Valve leak? #2
The seal around the spool is leaking - you will need to get a kit from the dealer. Its a white Teflon seal and a back up ring I think. Easy repair. Not how the old seal is installed before installing the news seals.
Land Honor 40 gal 2 Stage Air Compressor (A50515)
Land Honor 40 gal...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
Unused Delta Crash...
Ingersol Rand 100 Air Compressor (A50774)
Ingersol Rand 100...
2015 Ford F-550 Chassis Truck (A50323)
2015 Ford F-550...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
