Loader Massey 1205 Compact Utility Tractor Loader Valve leak?
   / Massey 1205 Compact Utility Tractor Loader Valve leak? #1
hb2u
MF 1205
Howdy folks. I'm hoping someone here can give me some guidance on fixing a leaking control valve.
I have a Massey 1205 compact utility tractor with model 1242 loader. it's got a Nimco control valve with a joystick for the loader.
The rear of the valve has developed a leak. The oil appears to be coming from the Caps at the rear of the unit that cover the spools.
What I'm not clear on is whether or not this is an issue with the gasket for the cap, or an o-ring on the spool itself that blew out and allowed oil to get as far as the cap.
There's a couple of little allen screws that hold the caps in place and I tightened them a little, but it did not slow the leak .
I'm mechanically inclined, but this is my first tractor with hydraulics, so I'm not familiar with how these things go together and come apart. Any tips/tricks/or noted special tools that might be needed would be greatly appreciated.
Am I wrong in thinking that I can just replace a couple of o-rings to fix this?
Thanks for your input.
HB
   / Massey 1205 Compact Utility Tractor Loader Valve leak? #2
The seal around the spool is leaking - you will need to get a kit from the dealer. Its a white Teflon seal and a back up ring I think. Easy repair. Not how the old seal is installed before installing the news seals.
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
2016 MACK (A50323)
2016 MACK (A50323)
