massey 1030 three point hitch wont lift
   / massey 1030 three point hitch wont lift #1
rangedriver1
windsor
1030 massey
my three point hitch just stoped working i checked the hyd oil and was low so i added tractor hyd but still wont lift is it air locked and if so how or what do i do to fix it
   / massey 1030 three point hitch wont lift #2
You can try this, which is what my 1010 Owner's manual indicates following a fluid change:
Lower the 3 pt hitch
Start tractor
Operate all hydraulic controls repeatedly
Check oil level, and add as needed
Repeat
Good luck.
   / massey 1030 three point hitch wont lift #3
Hello rangedriver I have the same problem, and I see another person with same problem. Did you get a fix, and can you tell me what was wrong? Thanks Don
   / massey 1030 three point hitch wont lift #4
Hello Lambs I have the same problem. I see other people with the same problem on same tractor. Did you get a fix on yours? If so can you let me no. Thanks Don
   / massey 1030 three point hitch wont lift #5
Have you tried to raise and lower about ten times.
If there is air in the hyd system, b operating the system yo will purge any air.
The pump is pumping fluid at all times, so the air is urged in the main line ina couple of seconds.
All the cyl need to be worked to rid the system of any air.
   / massey 1030 three point hitch wont lift #6
Hello J-J Thanks I will try it afew more times Thanks Don
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
378811 (A51573)
378811 (A51573)
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
