Massey 1020 drive shaft removal
   / Massey 1020 drive shaft removal #1
little diesel
I need to drop the drive shaft for the four wheel drive so I can remove the oil pan. I have a manual ordered but wont have it for a few days.:mad: I don't have the patience to wait for it . This is the first time I'm doing something more than just oil changes and lubes......Ok to my question . This drive shaft is mounted by 3 bolts on the back and 2 on the front of the shaft . After removing these bolts do I have to remove the front of this axle housing to slide the drive shaft forward or how do I get it to drop? I've tried to find this information on line but can't find it. If I need to supply more information for help please ask away. I will try and tell you what I know. Thanks
   / Massey 1020 drive shaft removal #2
G'day don't know your machine but most have a cover over the shaft can you slide yours together to see an inner shaft and locators??
Jon
   / Massey 1020 drive shaft removal #3
Jack up the front of the machine, Disconnect the steering, Loosen the hose clamp on the middle of the driveshaft, remove the 2 bolts and slide the whole front end forward. It's just on a spline. When I split mine I moved the whole front 1/2 of the tractor but you should be able to go it just by moving the front end.
Thanks racerboy832. I got your reply a little late. I rely on my posts always showing up on my phone and they don"t. What I ended up doing was taking the four bolts out that holds the front axle like you suggested . But then I blocked up the tractor and put a jack under the axle and removed the tires. Then I was able to lower the axle low enough to slide the oil pan past the drive shaft. Just another way to skin the cat....I really appreciated everyone help on here.:thumbsup:
   / Massey 1020 drive shaft removal #5
hi I/m about to do a drive in a mf fourwheel drive have to replace 2 u joints how do I go about it
DEWALT 4400 PROFESSIONAL GAS PRESSURE WASHER (A51248)
DEWALT 4400...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
