Massey 1020 alternator
   / Massey 1020 alternator #1
Dave1158
Brooklet ga
Massey 1020
I have a massey 1020 with with a 6 wire (red,yellow,green,black, blue and blue)voltage regulator pn-RS5104 and a 2 wire alternator pn-GP9153. The 2 blue wires on the voltage regulator connect to the 2 wire alternator. Does anyone know if those 2 wires must connect to a specific wire on the alternator?
   / Massey 1020 alternator #2
Hi Dave, congratulations on your first post here.
Don't be put off by slow replies because when you do get a reply it is usually good information. Eventually you'll get a response, so hang in there.
I have a Massey Ferguson 1010. It's probably very similar to your 1020 in many ways and probably shares many parts. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will see if it helps.
   / Massey 1020 alternator #3
I have a Massey Ferguson 1010. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will se if it helps.
The MF1010 Wiring Diagram shows the 2 Blue wires going to the alternator, each connected to opposite ends of a coil in the alternator. There is no indication on the diagram other than that the 2 blue wires connect to the alternator. HTH. C;lem
   / Massey 1020 alternator #5
Thanks Workstead
Hi Dave. In my reply to you last September I said that sometimes it takes a while to get a reply, but the information is usually good. You just proved the accuracy of that statement! :) Clem
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2015 INTERNATIONAL MA025 (A52472)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
