mashed / squished push rods
/ mashed / squished push rods #21
I’ve seen pictures of valves hitting pistons after a timing chain failure. What ever happened to the top of that one wasn’t that severe. What do the valves look like?
It certainly was not a severe impact with the piston. The valves look fine from what I could tell, but I dropped the head at the machine shop and did not take the valves/springs apart.
I was fine with the theory that the engine overheated and the valves stuck a bit - maybe oil pressure was down due to the wear on the oil pump so the valves were not getting as much oil as they should.
/ mashed / squished push rods #23
This sounds plausible.
John Deere 230 Disc Harrow (A66285)
John Deere 230...
3-Pt Hydraulic Tree Spade (A66285)
3-Pt Hydraulic...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
