Tiller Maschio Rotary Tiller
   / Maschio Rotary Tiller #1
mjdtexan
Houston(ish) Texas
Case IH 1140 (first tractor ever)
I lucked up and got this tiller for free. I dont know much about them. Are there any do's or dont's that I need to be aware of? It is made in Italy. It is a 42 inch model that will offset.
   / Maschio Rotary Tiller #2
Sweet find!!! I can't see a pto driveline in the photos, does it have a slip clutch? If you have a lot of roots or rocks, that will help protect the tractor. Don't forget to check oil levels...
I actually had the shaft off at the time because I had to clean it up. The tractor end of the shaft was stored in the dirt. I worked on that for about two hours with a wire brush and a file before it was usable.
I am not sure what the "slip clutch" thing is but I am going to do a googe search to find out. Thank you for the response
Is this what one looks like? I dont think I have that. I found this image in google images
   / Maschio Rotary Tiller #7
Yes you got lucky, I just paid four hundred for a 50 inch tiller identical to yours.Mind is a 1995 model that's been sitting outside without being used for about nine years I've been told. It has some deep rust in spots.Mine has a Waltershceid pto shaft with a slip-clutch and it also came with a shear bolt connection. I need new pto shaft which if I knew was so expensive I would have tried to bargain more on the price. I haven't had the slip-clutch apart yet to see if it is salvageable. I think Landpride uses the same setup on their tillers.I did get an owners manuel for it but before the seller found it I email the company and they were very helpful.If you have any questions just ask this is also a learning experience for me also.
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2019 TAKEUCHI TL8 SKID STEER (A52709)
2019 TAKEUCHI TL8...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
(INOP) MASSEY FERGUSON 2614H RIDING MOWER (A58374)
(INOP) MASSEY...
1272 (A58374)
1272 (A58374)
