Maschio Jolly 2016 5 ft finish mower, Mahindra branded
   / Maschio Jolly 2016 5 ft finish mower, Mahindra branded #1
John Fitzgerald
Elkins, Arkansas
XJ2025H same as NH Boomer 24
I recently purchased this mower used, and I found some side play in the spindles, which may indicate they need to be rebuilt with new bearings. Has anyone on here ever rebuilt spindles on this model mower? They have a 4 bolt square pattern housing. A thin 25 mm slotted self locking nut is on top of the pulley, and it uses a 18mm x 1.5 nut to secure the blade. The spindle shaft has to come out from the bottom. There is a grease fitting in the top of the shaft.
   / Maschio Jolly 2016 5 ft finish mower, Mahindra branded #2
The spindle and bearings are replaced as a unit. You can send MASCIO an e-mail with the mower serial number and I am sure they will send you a pdf of the owners manual to help you.
I have some new bearings on hand from Brooks Ag Supply. Supposed to be able to just replace the bearings. I was wondering if anyone on here has had that experience. Thanks.
2014 Doosan DA30 (A53472)
2014 Doosan DA30...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
