Marvel-schebler
/ Marvel-schebler #1
Diggerdon1
Marysville, Washington
Ford 860/ Ford 821
Ford 821,172cid,TSX813 carb. ruined the bowl trying to rebuild it. Want to use the tractor not restore it (backhoe & loader). Trouble finding a tsx813, used or rebuilt(cost). My question is if I find a, TSX with the same mount 2 11/16 cc, throat 1 5/16 Dia & air intake. Do you think I could get it to run my 172 cid. I would stay with a TSX for the rebuild kit. I know the 813 is a big bowl to give it enough fuel. Any suggestions welcome.
/ Marvel-schebler #2
I've read that some Marval's can be replaced with a Zenith carb. Never tried though.
Type your Marval numbers into a search engine to see what appears.
/ Marvel-schebler #3
/ Marvel-schebler #4
Tractor tech. I had a Chinese replacement that I never got to run right. I finally found a marvel replacement and it got it running about right. Still the float sticks from time to time but I can get by with it. It the only gas burner I have and the only one I have problems with.
/ Marvel-schebler #5
Here is a replacement
You should be able to get that carb for less money. They are common to a bunch of different engines. I hate how the float level is adjusted by using shims under the main jet since there isn't a (good) way to adjust the float. Also the outside of those carbs is permanent-rusty so don't be afraid of rust on the outside. I just rebuilt one of those things last spring for a 4220 we bought, fixed and sold.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
