Marking / taging / labeling hydraulic lines the cheap way.
   / Marking / taging / labeling hydraulic lines the cheap way. #11
Both my Kubotas use color coded dust caps such as these on the FEL lines.
I do use color coded zip ties on other implements though.
   / Marking / taging / labeling hydraulic lines the cheap way. #14
I was going to go this route until I needed to know the exact route each line took in
My New Holland came with these in 2007. Loader has never been unplugged or removed from tractor since new.
   / Marking / taging / labeling hydraulic lines the cheap way. #15
After reading this thread I used zip ties, but I only have a bag of white ties(1,000), since my outlets are numbered, the proper line has the same number of ties on the hose.
Lol technically you could follow each hose in the dark by braille that way.
   / Marking / taging / labeling hydraulic lines the cheap way. #17
Yep; of course we farmers never work after sunset___.šŸ˜„
   / Marking / taging / labeling hydraulic lines the cheap way. #18
My tractor came with colored zip ties. If I were re-plumbing a tractors hydraulics, I would probably get some of the PET Expanding Wire Sleeve, and some marine grade shrink tubing to secure it. It comes in a huge selection of colors. Including base colors, with different colored tracers. The operating temperature range is -40C to 150C. So, it should survive well on a tractor.
   / Marking / taging / labeling hydraulic lines the cheap way. #19
My Deere also came with the color-coded dust caps on all lines. Lots of them, given my rear remotes, power beyond, hydraulic top link, and third channel out to the loader. They work great, but can be a bear to get off the male coupling in cold weather.
   / Marking / taging / labeling hydraulic lines the cheap way. #20
I have those dust plugs but every time I went to use them they were grimy with dirt. I bought a box of tiny zip-loc bags, and now I just put one over each end and use a twist-tie to keep the ends clean when unused.
SWEEPER (A58374)
SWEEPER (A58374)
MCCORMICK INTERNATIONAL 10 FEED WAGON (A52708)
MCCORMICK...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
IRanch Mini Excavator Auger (A57149)
IRanch Mini...
2012 Ford F550 Dump (A55272)
2012 Ford F550...
