Map bronze solder a car radiator?
   / Map bronze solder a car radiator? #1
Sebculb
SW Costa Rica
'97 Deere 310D Backhoe
Hola everybody,
Anyone got any insight as to this would work (well)? My buddy that does refrigeration work was showing me how to braze or solder copper tubing with bronze stick and a map torch. My first time playing with it. Seems pretty straightforward, at least for the easy situations, just like welding.
So would this work to plug up a hole in the top part of the radiator on my 87 Toyota 4runner? It's right next to the cap and squirts water so it's easy to find and id prefer to not have to pay a professional to do it. Epoxy didn't work. I think it's made out of steel, there's rust in the water at least.
Thanks for any advice,
Sebastian
   / Map bronze solder a car radiator? #2
The trick to soldering is to CLEAN very well.
   / Map bronze solder a car radiator? #3
The radiator should be brass, the leak is on the top tank, by the filler neck, correct? Since it's probably painted black, scrub the paint off with some scotchbrite and see if it's the brass yellow. You could solder it with plumbing solder as that requires less heat than brazing, and less likelyhood of the hole getting bigger as you chase it.
If the hole is above the cores, make sure that there is coolant above the seam where the tank meets the core to avoid heat transfer melting that solder joint.
The rusty coolant is due to the cast iron engine block, radiators traditionally are brass, or aluminum with plastic tanks; that vintage of Toyota should still be brass.
Thanks! Brass, eh? Does That mean bronze solder is NOT recommended, in that it melts too hot and will poke holes? Would plumbing solder be the way to do it "properly"?
Thanks again
   / Map bronze solder a car radiator? #5
Be very careful on the solder you choose for the repair. The neck is probably soldered on with something like 50/50. If you get a solder that has a liquidus higher than the neck solder you will have things falling apart while you try to fix the hole. That being said, How large is the hole or is it a crack? There are several sure fire fixes. Plumbing solder will work with the proper flux but try to get something that melts around 430 or less. You need to find out if it' Steel ( doubt it ) Brass or Aluminum. None of the Plumbing solders will work on aluminum but there are some Aluminum solders out there. We can get into that when we know for sure what the base metal is.
   / Map bronze solder a car radiator? #6
Buy a new radiator. If it has one hole it will develop another.
Thanks​ everyone! Pretty sure it's not aluminum, I'll check with a magnet when I get home if it's steel or brass
   / Map bronze solder a car radiator? #8
I used plumbers solder to fix a radiator on a Model A in 1975... still holding up fine.
I think bronze or brazing like used for HVAC would be problematic since it requires more heat... just my opinion.
   / Map bronze solder a car radiator? #9
I agree that brazing would be too hot. I'm pretty sure the flues are soft soldered to the header. Same with the tank.
We had a whole building generator develop a leak on the radiator tank. Repair guys had it soldered instead of replacing it. Tank cracked two inches from the repair and ran all the coolant out. Overheat safety shutdown failed and fried the V8 engine. I don't know how much the engine rebuild was but it didn't last and the whole generator had to be replaced. Lost years of research samples because someone saved $400. Car radiators are even cheaper.
   / Map bronze solder a car radiator? #10
Not a lot of old fashioned radiator shops around here anymore... there were a few artists that could build what ever you needed.
A friends was doing engine swaps and always needed a custom radiator... no problem.
I towed a lot with my 318 Valiant... in the mountains the temp would push the needle... mentioned it to the owner of the shop and he said lets build one with a truck core... never had another issue and I have owned this vehicle 40 years now...
Some of the classic cars can have radiators well over a thousand dollars...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
Electric Mobility Scooter (A51694)
Electric Mobility...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
