manure spreader need help!
   / manure spreader need help! #11
They would have to be worn A BUNCH to consider welding them up. Tighten the drive chains ... the two levers each have a purpose. One is for the Apron and one for the beaters. Each notch sets the speed of each.
If the beaters stop I would think your apron speed is to fast and feeding to much material to them ... slow them down and speed up the beaters ... just my thoughts.
Side note: The manure spreader was invented in China by a man they called "Fling S*it High"
Good point, there is a turn buckle to back off the feed speed, make sure it is feeding as slow as possible. If the sprokets are as bad as mine were, though, it still will slip with a heavy load. The other thing is to put some sawdust or hay on the floor of the spreader before loading so the load can slide easier.
   / manure spreader need help! #12
like i said before....
Shoup Manufacturing Company
they will mail you a catalog. it has nearly every part needed to fix manure spreaders. i fixed up my old 1940's era spreader, and it works great. moves large loads of wet manure. wasnt expensive to repair either
I orderd the catalog a few days ago, from shoups! How do you tell what size chain you have?
I have the feed side working, I tried the slow feeder speed but the beater chain still skips then bounces off the gear, I would like too try a new chain first being the cheapest to see if that helps!
I have taken a link out of the chain too tighten the tensiion up a bit but it still skips then jumps off!
   / manure spreader need help! #14
I have taken a link out of the chain too tighten the tension up a bit but it still skips then jumps off!
there are numbers stamped on the chains. if there too warn out to read the number, the catalog has dimensions and pictures so you can compare.
i replaced one entire length of my main drive chain because the old one kept jumping off, and now it stays in-place.
   / manure spreader need help! #15
You may also need to add an idler to keep some tension on the chain. Seems like mine has one? I'll take a look.
   / manure spreader need help! #16
A number 17 is a great spreader, you just have to understand what it is capable of. I still have a #12 that does a great job. It can be filled to the point that no more will fit on it, and it does a great job.
Let's talk generalities about these units. If being loaded with an FEL, you need to break the stuff up some first. Digging large piles of straw and wet cow manure, makes it very hard on the unit. The leaver on the right that controlls the drag chain has numerous settings as to how fast the chain moves. If you are running really wet stuff, only set it in the middle. The betters only have one setting, on or off. I have never had one jump that chain off the sprocket. The sprockets vary a lot from 12-12A-17-206, each is different. Same operational idea, but different axles etc. Does the chain come off during spreading, or when you are stopping? If you stop too fast after the load is gone, I could see it jumping off then.
In your driving this spreader, how fast are you driving? They were only ever ment for a ground speed of about 3to 4 MPH. You may be able to push 5 if you are lucky and loaded with dry stuff.
The ratchet drive for the drag chain, probably just needs cleaned up and lubricated, or maybe the spring for it is gone or week. Some had springs, some did not. If those ratchet teeth are warn out and the beater sprocket is worn out (never seen this happen, seen them break, but not worn out) time to get another spreader.
The beater sprocket is cast, and none of the castings are available new any where. Used parts are the only thing you will find,and they are getting harder to find any more. I used to rebuilt these for the horse people in the area, but the supply of spreaders and parts just got too small.
   / manure spreader need help! #17
We have a 17 that we used for many years before we sold the cows. It was pretty bulletproof once everything was adjusted. I am getting it ready to sell and needed a new guard and found this site when I was looking. Hope it helps.
new idea spreader parts
   / manure spreader need help! #18
I would say sell it. Buy something newer and useable same brand or different.
Theres a lot of folks with lots of time looking to restore something. Here in the mid south manure spreaders are very popular. Almost everyone has one, and they bought in the last 5 years most are ancient and nearly useless. Many pay upwards of 1000 for something when they have only a few loads to spread.
Yes I have a spreader Gehl 315 Scavenger II
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
2017 BMW 540i Sedan (A55853)
2017 BMW 540i...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
