Spreader Manure Spreader Advice
/ Manure Spreader Advice #1
JUBILEE1953
Ohio
MF 1742 TLB - Ford NAA
Shopping for a smaller (50-80) manure spreader. Deciding on ground or pto driven. So far I looked into H&S, Pequea, AGI, and Conestoga.
/ Manure Spreader Advice #2
I had a older john deere ground driven spreader that worked great unless it was muddy out or in the snow it didn't work well. the 34hp with hst wasn't quite enough to tote it around quickly up hills either. I moved onto a 3622 New idea and pull it with the john deere. Its pto driven but I wish it had float tires.
/ Manure Spreader Advice #3
The issue between ground driven and PTO drive amounts to what kind of manure you have to spread. Cow- PTO driven. Pig- PTO driven. Horse or sheep ground driven does well.
/ Manure Spreader Advice #4
If you haven't, check out the Millcreek Manure Spreaders, which are made by hand in Lancaster County, PA. They offer the traditional powder coated steel models as well as some awesome looking stainless steel models. I've personally sold them for around 10 years and they're premium, top of the line spreaders.
Manure Spreaders | PTO Manure Spreaders | Ground Driven Manure Spreaders
Travis
/ Manure Spreader Advice #5
I have a Pequea 80P I bought new 10 years ago, and pretty well satisfied with it. The paint is holding up on it very well. The only issues I have/had with it are...
#1. On the front belt drive, the pulley on the pto shaft is not exactly lined up with the drive shaft going back to the beaters. With heavy loads, it would spit the belt off. I shimmed the bracket holding it, so as to align, and haven't had any problems since. I called the factory about it. The guy I spoke with went out in the lot to look at one, so as to see what I was talking about. All the while, telling me it SHOULD be in alignment, and was probably a fluke. After he found one and looked, I heard... " Well I'll be da*#ed, this one is that way too. Checked another, and the same way. I suggested he might want to mention it to someone, and get the problem solved. I checked an 80P a few years later at our County Fair, and pulley's were still out of alignment.
#2. The apron speed seems a little fast with heavy manure. It does have 2 speeds, and I have it set on the slowest. Being used to an older spreader with multiple apron speeds, other than 2, one more slower speed would be a great improvement. Not sure what other brands have.
#3. Mine has a single beater. My old one had multiple beaters. You don't get near the quality spread with a single. They do, or did offer multiple beaters, but was a, I believe over $600.00 option at the time.
Being I'm at different farm now with much flatter ground, I may try to find a good used larger spreader with multiple beaters. They seem to do a much better job shredding chunks, or gobs that come out of the storage bin.
For fluffy horse manure straight out of a stall, they do great, just don't load it higher than the beater at it highest point, in rotation. Anything higher than the beater will get dragged off in a big sheet, if using long stemmed straw for bedding. If using pine shavings, I'm sure it would do great.
If I had cattle, I'd definitely look for a farm rated spreader, like New Holland, etc.
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
CAT 315CL 42" Bucket (A68134)
CAT 315CL 42"...
2016 Toro ReelMaster 5510-D Commercial Reel Mower (A66734)
2016 Toro...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2007 MACK VISION (A67714)
2007 MACK VISION...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
