Front-End Loader Manure fork mounting on a pallet fork
   / Manure fork mounting on a pallet fork #4
Just wondering, how come not just with the bucket, too small bite? :)
The loader lifts1000 pounds 500 kg
with this load the tractor nearly stands on the front wheels
the load on the image is about that limit fresh cowdow are quite heavy
so the bite is not to small and we can now use this palette fork for other kind of work.
   / Manure fork mounting on a pallet fork #6
Looks very good. :thumbsup:
Can you post some pictures of it on the three point?
Yes best Elite Member :newhere: here is a Dropbox image with the Pallet fork in the three point.
The ballast is 1 102 pounds 500 kg easy to pick up and set aside when you use the pallet fork fore lifting heavy loads that the front loader is unable to lift
   / Manure fork mounting on a pallet fork #10
Thankyou PhysAssist you should Report Post
it should may be have been posted in Forum: Build-It Yourself
NO, I'm sorry, I didn't realize this was a DIY project you had posted- I thought it was a commercial manufacturer or someone spamming for one.
Between the slickness of the build and the similar qualities of the website, I thought that someone was getting a freebie advert for their shop.
Thanks for your patience.
Thomas
PS: Nicely done!
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Ford 655C 2WD Cab Backhoe (A55314)
Ford 655C 2WD Cab...
