Manure/compost fork for FEL
   / Manure/compost fork for FEL #1
michaelfree
Greetings AllDoes anyone have a design for a manure/compost fork that can clamp or bolt on to the FEL (BX 2200)?cheersmichael
   / Manure/compost fork for FEL #2
Manure forks usually have a number of tines. If you have a tooth bar, replacing the teeth with longer tines would work. You might have to custom build something. You'll have to make the tines strong enough to support the load. I'd look into a design that extends back into the bucket and sandwiches the upper and lower surfaces to spread the load out.
If you don't have a tooth bar, you should be able to come up with a clamp on arrangement for the tines that would work.
   / Manure/compost fork for FEL #3
I moved a very large composted pile of horse/mule manure with my B7500 FEL equipped with the tool bar. The bucket went into the pile and came up with an overfull bucket first try almost every time. Maybe just try the bucket with a tooth bar first.
Bonus, having the tooth bar which is great for so many other uses and not limiting the bucket with the forks.
2024 Ex Mark Lazer Z 60in. Zero Turn Commercial Mower (A55973)
2024 Ex Mark Lazer...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
Deere 333G (A53317)
Deere 333G (A53317)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
