Manure/compost fork for FEL
   / Manure/compost fork for FEL #1
michaelfree
Greetings AllDoes anyone have a design for a manure/compost fork that can clamp or bolt on to the FEL (BX 2200)?cheersmichael
   / Manure/compost fork for FEL #2
Manure forks usually have a number of tines. If you have a tooth bar, replacing the teeth with longer tines would work. You might have to custom build something. You'll have to make the tines strong enough to support the load. I'd look into a design that extends back into the bucket and sandwiches the upper and lower surfaces to spread the load out.
If you don't have a tooth bar, you should be able to come up with a clamp on arrangement for the tines that would work.
   / Manure/compost fork for FEL #3
I moved a very large composted pile of horse/mule manure with my B7500 FEL equipped with the tool bar. The bucket went into the pile and came up with an overfull bucket first try almost every time. Maybe just try the bucket with a tooth bar first.
Bonus, having the tooth bar which is great for so many other uses and not limiting the bucket with the forks.
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2014 UTILITY...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
