Manuals
   / Manuals
Say what?
What ever you do 1930, don't get rid of the OEM service manuals you have!
Ill trade all I have for just what I need, a parts manual and a service manual
   / Manuals
First - The manual may be online Kubotabooks.com
Kubota usually puts out 3 manuals for each tractor a WSM - Workshop Manual, a Parts manual, and an operators manual. All 3 are well worth having if you expect to work on your tractor.
Based on the pics in your other thread those manuals or a credit card and a good dealer will be needed.
It's not rocket science, but it's also not sweeping floors.
There are three prime methods of PTO connections, sliding collar, pin and one other.
Here's an older primer https://articles.extension.org/sites/default/files/NSTMOP Task Sheets Section 5 2013.pdf
Study that and Google a bit.
There will be a test when you try and unhook it.
Thats nice link, thanks
   / Manuals
I see the parts manuals are avail on e-bay, how do I date my machine so I can get as close a manual as possible assuming there were big changes to the machines?
I was told the tractor was a 1980 but who knows at this point
   / Manuals #14
Ok so I read thru my owners manual and I have a few more questions.
It states there is a separate implement manual, the owners manual has little to nothing in it about implements.
At this point I don't know a single thing about connecting/disconnecting/using the one implement I have now never mind what I still need to get a trailer hooked into the back of my Kubota.
Can someone here help with that manual?
Also I received the manuals I show below with tractor but I don't see how any of this pertains to my machine?
What is the implement and what is the question?
I am assuming its a 3PH implement you are asking about. It's hard to ask for help on an "implement manual" when you don't say what the implement is...
   / Manuals
It said in my manual that there was a separate manual for implements, I assumed that manual would show me usage and proper care in general. That's what I was looking for
   / Manuals #16
It has moved to a higher power - good fortune to all.
   / Manuals #17
When I bought my B2320 it came with a FEL, back blade and rotary cutter and I got a manual for each. I’d guess you don’t get implement manuals unless you buy the implement.
In your case just decide what implement you want then look up a manual for it. You might be able to download owner/operator manuals for each if you specify the model number.
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
IRET13 ELECTRIC TRICYCLE (A58216)
IRET13 ELECTRIC...
