Manual Water Temperature Gauge.
   / Manual Water Temperature Gauge. #1
thedon
Sutherlin, Oregon
Satoh S650G
I own a 1972 Satoh S650G tractor that I have had for about 5 years now. I've been wanting to install a manual water temp gauge but have found that the only place to install the manual temperature sensor is where the original pilot light sensor is. The problem that I'm finding is the threads where the original pilot light sensor screws into are standard threads, not pipe threads and the pilot light sensor also has a "O" ring on it. I need help trying to figure out how can I or what can I use to make the manual temperature sensor work. If anybody has installed one before on their S650G please let me know. Thanks
   / Manual Water Temperature Gauge. #2
Have you thought about using a radiator hose adapter? Find the diameter of your hose and go from there. Pretty simple and you won't have a "stack" of fittings to deal with. Google will return many suppliers. Check ebay too.
SimS
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
LOT LOCATIONS (A54313)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
ITEM LOCATION (A53084)
