Manual Shuttle......How to Shift Fwd to Rev
   / Manual Shuttle......How to Shift Fwd to Rev #1
Fergy
alexandria, ontario
Massey Ferguson 50c
I own a MF 50c with a 6 Speed Manual Shuttle Transmision. What is the correct procedure to shift from forward to reverse or vice versa. Is it necessary to shift the transmission and or High/Low into neutral, or can you just stop, press the clutch pedal and change directions? Thank you
   / Manual Shuttle......How to Shift Fwd to Rev #2
If it is a shuttle shift then just push in the clutch and move the shuttle.
Dan
   / Manual Shuttle......How to Shift Fwd to Rev #3
I would only add to what has been said, that you want to come to a stop, before letting out the clutch, when changing direction. This will avoid taking the face off of the clutch.
Thanks JD & Baler. Just wanted reassurance I was doing it right. :thumbsup:
1267 (A50490)
1267 (A50490)
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
(1) MAYTAG REFRIGERATOR (A51248)
(1) MAYTAG...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
