Manual Shuttle......How to Shift Fwd to Rev
   / Manual Shuttle......How to Shift Fwd to Rev #1
Fergy
alexandria, ontario
Massey Ferguson 50c
I own a MF 50c with a 6 Speed Manual Shuttle Transmision. What is the correct procedure to shift from forward to reverse or vice versa. Is it necessary to shift the transmission and or High/Low into neutral, or can you just stop, press the clutch pedal and change directions? Thank you
   / Manual Shuttle......How to Shift Fwd to Rev #2
If it is a shuttle shift then just push in the clutch and move the shuttle.
Dan
   / Manual Shuttle......How to Shift Fwd to Rev #3
I would only add to what has been said, that you want to come to a stop, before letting out the clutch, when changing direction. This will avoid taking the face off of the clutch.
Thanks JD & Baler. Just wanted reassurance I was doing it right. :thumbsup:
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
HOMEMADE 4' X 4' DEER STAND (A51248)
HOMEMADE 4' X 4'...
JOHN DEERE 560M LOT NUMBER 139 (A53084)
JOHN DEERE 560M...
(APPROX 24) 2" X 3" X 39" TUBING (A51247)
(APPROX 24) 2" X...
DEWALT 4400 PROFESSIONAL GAS PRESSURE WASHER (A51248)
DEWALT 4400...
