Manual pto on /off valve?
   / Manual pto on /off valve? #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
Anyone with a pre-12v pto valve, the manual handle operated one...
What is the intended position for ON?
I think mine is not stopping where it should and causing some trouble in flow. This is on the 42x mystery machine.
It's by my right foot and off is handle vertical, on seems to be 90 deg. But nothing retains/stops the handle there. Maybe I knocked out a limit stud?
Thanks
   / Manual pto on /off valve? #2
My PT180 stops at 90 deg from vertical = off, to horizontal = on, 1/4 turn just like you assumed.
Thx, friend. I must be missing whatever limits the handle motion. I'll see if I can replace it or install something.
   / Manual pto on /off valve? #4
I like the manual control over the electric as it lets you modulate the start of the attachment. It seems the electric PTO goes full on when you flip the switch. Starting the mower blades is a shock. The manual control allows a "slip the clutch" gentle start. A good control.
Good point. I can see that. I just need the handle to stay put!
   / Manual pto on /off valve? #6
I looked at mine closer the other day. The rotating shaft/handle has a roll pin protruding which contacts a stop to keep it within its limit of travel. Look for a small hole in your shaft to tap in a roll pin. Maybe it walked out, if it fits loose, use locktite.
10-4 thx friend. I see the hole. I'll walk a pin right back in there.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2021 Deere 331G (A53317)
2021 Deere 331G...
1999 CHEVROLET C7500 UTILITY TRUCK (A57880)
1999 CHEVROLET...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
