Traction mantona 4344
/ mantona 4344 #1
montana 4344
Tractor engine dies after depressing forward or reverse pedal. transmission can be in gear or not the steel dies after depressing.
/ mantona 4344 #2
Check your seat safety switch. Does it do the same thing if you engage the PTO?
/ mantona 4344
checked out seat switch and it has been by-passed I should say that when I depress the forward and reverse pedel the tractor will start to move about and has you press the pedel harder the engine will die. Also checked out the if pto and it does the same thing, when you turn the switch the engine dies. thanks for the help.
/ mantona 4344 #4
Sounds like it dies under a load. Have you checked or changed the fuel filter latley? That may sound to simple but sometimes that's all it takes.
/ mantona 4344
Yes, I've change the fuel filter and the air filter. Thanks for the help.
/ mantona 4344
Does anyone know of a good repair person in the San Diego east county that could fix this tractor? Thanks again for the help.
/ mantona 4344 #7
I think you have a faulty safety switch or it is incorrecty bypassed. If it shuts down with the PTO on (nothing attached) then it isn't dying under load. I would check the seat safety switch again.
I assume it throttles up fine when not moving? If it runs good at WOT before touching the pedal then I would not suspect starvation.
/ mantona 4344
Thanks for info I have found the problem is in the safety system. I have taken a hose clamp and by-passed the safety switch on the pedal. The tractor now works fine. Keep Smiling.:thumbsup:
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2014 GMC Savana Box Truck, VIN # 1GD072CA5E1907870 (A65563)
2014 GMC Savana...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
