Manlift platform from a Woodmaxx pallet
   / Manlift platform from a Woodmaxx pallet #1
hslogger
Platinum Member
western oregon
currently l4400 stick
Woodmaxx pto chippers come partially assembled but crated with a platform and uprights made of rectangular tubing and angle iron. I had this thing sitting around wondering what I was gonna do with it. On the bottom I added some big C iron to house my tractor forks. A couple more pieces of angle on the sides, and a couple cross members on the bottom. Inside the tray measures roughly three feet by three foot six. I used bed frame iron and some flat strap. I think it is going to be real handy.
   / Manlift platform from a Woodmaxx pallet #2
one should have a system to chain it on and lock it in place, or pins in the ends of the forks to keep it from working off the forks.
I could have have welded some hooks on it for chain, but I will just run chain and binder around the fork assembly through the inside of the frame and it will be as secure as can be. Chipping paint here and there doesn't bother me. If I wanted to get picky I could wrap the chain in cloth or hose.
   / Manlift platform from a Woodmaxx pallet #4
I need something like this.
Tagged for more pics! (Hint, Hint, HS!!!!)
   / Manlift platform from a Woodmaxx pallet #5
I want to see how the floor goes in with all the angle welded on the inside.
   / Manlift platform from a Woodmaxx pallet #6
not the best picture but I built this platform a few years ago, out of a old frame about 12 feet wide,
what I like was the 2 x12 I put on the back side of it, made a good work table, and a place for tools,
I have removable frames on the front and chains on the sides of it,
also I put fork attachment points, on the ends and middle, one on the direct end so I could come into the end of it, and use it as well,
the fork lift we have will raise to 30 foot tall,
I have used it for a number of jobs like the barn siding and paint another barn,
Here are finished snapshots. I cut out the spots where the angle was in the way. That was fine. I hadn't quite bargained for the inconvenience of the board that had to be cut on the ends. It was just too tight to make it fit without cutting one end out more than I wanted. I wanted to make it a tighter fit, but the angle of the dangle didn't allow that, so I had to beaver it out, allowing me to set the board in the tray. I'm happy with it and wish I had this a couple years ago when I was tearing the side of my house.P7020011.jpgPC060035.jpgP7020017.jpg
   / Manlift platform from a Woodmaxx pallet #8
Looks good HS!
What are your plans, if any, to prevent a slip or fall down near the bottom of the lift? Isn't that one of the OSHA requirements to prevent slipping out the bottom?
   / Manlift platform from a Woodmaxx pallet #9
Looks good HS!
They call it a "toe kick" I believe. Technically to be safe it needs to have a couple of large metal hoops that you can tether your body harness to. You can go on and on with the safety rules, but it can get overdone. Like having the special valving in the hydraulics of whatever you are using for a lift, in case you bust a hydraulic line while someone is up in the lift.
   / Manlift platform from a Woodmaxx pallet #10
Yes, I agree, it can be overdone.
But, having said that, anyone contemplating making one of these should know what all the *major* safety requirements are so they can decide for themselves what's important and what's not.
Without the "corporate" knowledge - which by definition most of us don't have - it's hard to know what was learned in blood and in lives vs. what was mandated simply due to overzealous bureaucracy. As an engineer, I hope I can discern the difference, at least for my application.
Taking the "toe kick" as an example: I would want that in my application. Tripping, slipping and falling is on my list of "what not to do" when I'm up at high elevations. And, oh by the way, my definition of "high elevations" is about 6'!!! At my age, falling at any higher elevation than my couch is definitely not on the bucket list!!!
Enough digression, more pics and/or more safety requirements!
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
2005 International Pier Drilling Truck (A49461)
2005 International...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
FUEL TANK (A50854)
FUEL TANK (A50854)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
